Battery switch on dashboard 47 Lightning... >
Old 04-03-2010 | 03:45 PM
Yamaha 225's Avatar
Default Battery switch on dashboard 47 Lightning...
Hi guys,
I may have a dumb question here.. But on a triple engined 47 Lightning 1998 MY, there is a toggle swith right above the steering wheel... It is "off" in the middle, and you can flip it in both directions. It is related to the two volt-meters above it. But I wonder.. -How does this switch work?? Why is it only two voltmeters, then the boat has one battery for each engine + one for the generator...?? This does not make much sense to me.
This board is so nice ;-)
Erik
Yamaha 225 is offline
Old 04-03-2010 | 03:53 PM
Yamaha 225's Avatar
Default Hull shaking 1998 47 Lightning.
Old 04-04-2010 | 09:41 AM
you have 2 volt meters and 3 engines 2 engines share 1 gauge and the switch changes between those 2 engines on that 1 gauge
flat rate is offline
Old 04-04-2010 | 06:00 PM
Yamaha 225's Avatar
Thanks,
I can't believe why they did it this way, instead of just putting in an extra volt-meter..?
