RTV/ Ultra Black on intake gaskets? >
Old 04-05-2010 | 11:12 AM
ballon78's Avatar
Default RTV/ Ultra Black on intake gaskets?
How do you install your intake gaskets on 502's with factory alum gm intake, brass lines for salt water use.
Having a hard time sealing up the water ports on my 502, its a newmotor, with a new intake and it was leaking water into the top of lifter valley, wasn't mixing with oil yet, just puddles on top of oilplash shield.
Used Mercruiser gaskets before the ones with orange rings on one side and composit back. Looks like the rtv orange i used didnt seal up good on the underside of gasket.
Get very mixed install tips on weither to use ultrablack aroundcooling ports or run gasket dry.
Picked up a set of felpro 1211 and 17341gaskets..
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 04-05-2010 | 12:03 PM
I always use ultra black on the water ports. about 10-30 intakes a year
JIMG is offline
Old 04-05-2010 | 12:06 PM
ballon78's Avatar
do u use felpro intake gaskets or mercruiser oem ones, i have both..
ballon78 is offline
Old 04-05-2010 | 12:09 PM
i used the ultrablack for years,but their is something much better and i now use it all the time,it is called the right stuff.it seals much better than ultrablack.
mike tkach is offline
Old 04-05-2010 | 01:25 PM
ballon78's Avatar
where can u buy that? You use it on the valley and around the cooling ports....
ballon78 is offline
Old 04-05-2010 | 02:19 PM
ballon78's Avatar
Mike just found it at autozone its called 1 Minneut Gasket maker by Right Stuff...is that what your talking about? Does it set up fast? Doing it after work tonight.
ballon78 is offline
Old 04-05-2010 | 03:40 PM
The Right Stuff works great just read the instructions on the back
sets up great and seals great
cbellamore is offline
Old 04-05-2010 | 04:07 PM
Default fixx
rite stuff and ultra black is almost the same stuff,,ultra black is a little thinner,,when applying the surfaces have to be oil free so wipe down the surfaces with fast dry brake clean or lacquer thinned or the rite stuff wont stick..
WARNING!!
once the rite stuff is applied and Set's up good luck getting it apart!
i used it once on a diff cove and had to take it back odd a few weeks later,i bent the piss out of the diff cover to get it off!
FIXX is offline
Old 04-05-2010 | 04:27 PM
I like the Mr. Gasket ultra seak gaskets the best..
ezstriper is offline
Old 04-05-2010 | 05:17 PM
I use the ultra gray, its seems to hold up better than the black
SHAWN DAVIS is offline
