Bravo 1 4 blade stainless prop question >
Old 04-05-2010 | 01:07 PM
Default Bravo 1 4 blade stainless prop question
Friend of mine has a used Bravo 1 four blade stainless prop he want to sell to me. It has about 2 inches broken off one of the blades.How much is a 4 blade prop worth with one broken blade? How much to have it repaired. thanks
89 Baja 250 is offline
Old 04-05-2010 | 01:18 PM
articfriends's Avatar
It's not worth much on top of the fact that if your boat only has a 454 in it theprop better be a 22 pitch or so other wise you will never pull it unless your motor is modified. Your going to have to get it repaired,figure 200-300 dollars for that then is it even the right prop? Smitty
articfriends is offline
Old 04-05-2010 | 01:26 PM
Thanks. I have the stock prop now. But down the road. Would like to get a bigger horsepower motor.Is $50 to much?
Old 04-05-2010 | 02:30 PM
Dave M's Avatar
Veteran: Navy
I'd make sure it was repairable before considering buying it.
Dave M is offline
Old 04-05-2010 | 02:38 PM
IMO, Its a waste of money to buy it.
Griff is offline
Old 04-05-2010 | 03:27 PM
Tell him you will give him $.50cents, the only thing you can do is sell it for scrap metal. If it could be fixed, he probably would have aready fixed it.
Greenkeeper is offline
Old 04-05-2010 | 10:37 PM
Friend just bought a house. The prop was in basement. You guys know more than me. I will pass on it. Let see if he gives it to me. . Thanks again. Mike.
Old 04-06-2010 | 04:32 AM
i have a 24 4 blade that i will be selling in the future if you go to bigger hp. 1 is labbed, the other stock... mark
mookymonkey is offline
