38 Fever ssm IV props >
Old 04-06-2010 | 07:37 PM
Default 38 Fever ssm IV props
I just got a 1990 38 Fountain Fever. Has 1.5 ssm IV drives. Gonna need a starting point for props. Will be putting my 600HP engines in it. Any insight would be good as for a starting point. My buddy has some 19 spline 17x27 4 blades he said i can borrow. Looking to be in the 5300rpm range wot.
MILD THUNDER is offline
Old 04-07-2010 | 10:37 AM
sac
I have 26 4 blades if you need them
sac is offline
Old 04-07-2010 | 09:26 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Try the 17x27's!!
I think they will give us a great base line to work off of.
B
[email protected]
bbladesprops is offline
Old 04-16-2010 | 12:51 PM
Brad Zastrow's Avatar
I have a set of 29 x 16.75 five blades.
Brad Zastrow is offline
Old 05-19-2010 | 07:26 AM
Found some 17x28 3 blades. Would these be worth trying out with the drives mounted high? The shafts are about 2" below the bottom. Know of another 38 fever with similar power who runs 17x29 3 blades but with ssm III's
For the guys above who have props, are they 19 spline or 26?
Old 05-19-2010 | 03:26 PM
Yes...becasue that is not high for a SSM drive set up !!!!!! THATS LOW !!!!!!!!! specially on a fountain !
I think u need like 17 X 28 - 30 4 blades ?!
DareDevil is offline
Old 05-19-2010 | 04:05 PM
Smile
However, it is a 1990 hull. I think you'll like the 4 blades better.
B
[email protected]
Old 05-20-2010 | 11:14 AM
[QUOTE=MILD THUNDER;3113909
For the guys above who have props, are they 19 spline or 26?[/QUOTE]
Mild i have some 19 spline 16.5 X 24's i need to sell let me know i am close to you.
Attached Thumbnails 38 Fever ssm IV props-24s-002.jpg   38 Fever ssm IV props-24s-001.jpg
Car Biz is offline
Old 05-20-2010 | 11:18 AM
I dont think theyd be enough. Guessing the boat should run around 80mph with the power i have, from what ive found out history wise about the boat...1.5 drives, guessing i'll need to be in the 27-29p range? 5200-5400 Rpm is where i need to be...
Old 05-24-2010 | 01:08 PM
I have a set of 4 blade 18 " 33 pitch 26 spline if you need them
ultimate weapon is offline
