350 mercruiser oil leak need help. >
Old 04-11-2010 | 08:00 PM
Default 350 mercruiser oil leak need help.
I have a sea ray pachanga I have just purchased and I took it out today ran it for 30 min and thought I should check the engine. I found that the motor was leaking oil in the lower front end where the timing cover and oil pan meet.
Could this be the main seal? If it is can I replace this with out pulling the motor? or could it be leaking oil pan or timing cover?
It does not leak oil from what I could see when running about 3500 rpm, only when running top end, and alot of oil starts comming out. I know a little about motors, looking for advice from someone that has had similar problem.
Thanks.
bigwelderboy is offline
Old 04-12-2010 | 02:23 AM
Same issues in this thread and same answers to look for the leak. http://www.offshoreonly.com/forums/d...r-leaking.html
Griff is offline
Old 04-12-2010 | 07:07 PM
ok thanks didnt know if that would be the same.
