Running off plane on a single engine. >
Old 04-13-2010 | 09:56 AM
Default Running off plane on a single engine.
I've noticed a trend in boaters with twin engine boats (both performance and cruisers) running on a sinlge engine while off plane. One can assume individuals are doing this for fuel savings.
Anyone else seeing the same? What are the risk's?
Wouldnt fual saving be minimal at best?
LowKey is offline
Old 04-13-2010 | 10:25 AM
I always shut all but one down.
Around Ft. Myers we have a number of slow zones.
One of the boats I sold had 50 hrs on it. When I pulled up the log on the Smartcraft, 27 hrs were between 500 and 1500 RPM.
Beside cutting down the hours there have been studies that show you do burn less fuel by running on one engine.
If you look at all of that it seems like there's no good reason to run more than one.
Of course if you have power steering on just one motor it gets a little trickier.
salesmanship is offline
Old 04-13-2010 | 11:00 AM
i usually shut down the one that's not running the power steering pump. Only do it in no wake zones, or marinas. saves fuel
rumrunner29 is offline
Old 04-13-2010 | 11:38 AM
I rarely shut one off. My power steering is on one engine and I have separate fuel tanks for each engine, so I leak to keep the fuel even. Running on one in a no wake would be way too slow.
Griff is offline
Old 04-13-2010 | 11:39 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
-Save hours and wear on the motor.
-Run slower.
-Depending on the boat, might not wander at idle. (Or might wander moreso.)
-Save fuel.
-Being a 'greener' boater.
-Less opportunity to suck something up or strike something when in shallow water.
or
-Already broke a motor/drivetrain, and are limping back in.
...all reason to be running on one motor.
The drawback, and hence why most fire up at least the two outermost motors when docking, is that you have next to no handling control with just one motor on a large boat. It's much easier and precise to dock/maneuver with both (outermost) motors around the docks/trailer/etc. A bowthruster also makes this process even easier.
Sydwayz is offline
Old 04-13-2010 | 12:56 PM
Steve H's Avatar
artselectricinc.com
I have a 42ft boat, 502 EFI's and a Floscan interfaced with GPS. My fuel economy will almost double by cruising on one engine at no wake speeds.
Steve
Steve H is offline
Old 04-13-2010 | 01:18 PM
Honestly I've never ran on just one motor before, but I would consider shutting one off now. Occasionally I do have to put one motor in neutral to slow the boat down at idle when going through canals and whatnot with people in front of me. Why not just shut it off? Makes sense to me....
I hear some people's motors "load up" or build fuel up when they idle for too long. They have to rev the motor to clear it out when it starts sputtering... seems to me the better solution would be to just shut that engine off.
wjb21ndtown is offline
Old 04-13-2010 | 03:21 PM
t500hps's Avatar
21 and 42 footers
In some no-wake zones I HAD to run on one only...but would often leave the other one running anyway. I guess it was because the engine/props on that boat I would idle at 9 mph and put out a 1ft wake. I was yelled at or stopped numerous times because of the wake I was putting out. Dropping one out of gear would slow me to 6-6.5 and virtually no wake.
t500hps is offline
Old 04-13-2010 | 03:32 PM
Interesting thread........If I idle for longer than a mile I would shut one off (usually the one that has more hours, so I could even up the hour meters if they are off by a bit).
However the savings could really kick in if you had big power. Merc. gets 50K+ to refresh a pair of 1075s so they "cost" $500 an hour to operate (just in maintenance). So if you had a 30 minute idle each way to get out to open water you could theoretically "save" $500 in just one outing by shutting one motor down each way. This number doesn't even add in the fuel savings....... Of course there is a value in warming up a cold motor before going WFO too....
Jupiter Sunsation is offline
Old 04-13-2010 | 03:57 PM
I started doing it last year in some of the long no-wake zones at LOTO. Not sure I'm really saving that much fuel, but figure I'm in no hurry anyway. Alternate the motors to keep the hourmeters relatively close...
Shallow Minded is offline
