hp 500 carb leaking >
hp 500 carb leaking
hp 500 carb leaking
Old 04-13-2010 | 11:06 AM
bdr67's Avatar
Default hp 500 carb leaking
hp 500 wont idle. too rich found fuel dribbling out of secondaries. needle and seat? saturated float? any ideas
bdr67 is offline
Old 04-13-2010 | 11:40 AM
Have you tried adjusting the needle seat/float level????
Griff is offline
Old 04-13-2010 | 01:44 PM
Default Fixx
what griff said,try removing the needle and seat,it will unscrew from the top..their may be a piece of crud in it,,look closely and if not replace both of them(front and rear)
FIXX is offline
Old 04-14-2010 | 05:15 AM
bdr67's Avatar
can the float levels get out of adjustment for no reason? ALSO TO ADJUST THEM DO YOU LET IT RUN AT IDLE AND SET IT JUST COME OUT OF THE WEEP HOLE?
bdr67 is offline
Old 04-14-2010 | 08:49 AM
I was gonna say it could be a blown powervalve, but i am pretty sure the 500HP carbs didnt use a rear powervalve.
I am going with some crud in the needle and seat assembly!
MILD THUNDER is offline
Old 04-14-2010 | 10:02 AM
Default Fixx
no! unless they were real high to begin with and unless you hit some major waves all the time then mabe..pull the needles,just unscrew them with a wrench not a screwdriver,this way you wont loose the adjustment..
yes pull the wheep hole plug and start the engine, WARNING!! if theirs somthing stuck in the needle and seat it will poar fuel out of the wheep hole so pull the needle and seat first and check it for crud..
FIXX is offline
Old 04-14-2010 | 11:50 AM
bdr67's Avatar
ok ill try that thanks guys
bdr67 is offline
Old 04-14-2010 | 12:09 PM
I am having the same problem with my HP500's. bdr67, let me know how it goes.
gater3 is offline
Old 04-14-2010 | 12:11 PM
Does anyone know what the model of the Holley carbs are on the HP500's? is it the 4500 by any chance....... http://www.holley.com/data/TechServi...ded%20View.pdf
gater3 is offline
Old 04-14-2010 | 12:45 PM
The HP 500 carbs are Holley 4150's --800cfm, model 9022.
No rear powervalve in them.
Griff is offline
