more octane questions >
Old 04-13-2010 | 02:22 PM
Default more octane questions
If your running twin merc 454 mag MPI's with a little ECU work and different exhaust and breathers. Should we use a booster if all we can get is 89 or 91 at the dock..
Stock comrpression.. Or are we good at 89-91... Does the lead cause any issue with the fuel injection?
Would like these motors to last me awhile...
silent lucidity is offline
Old 04-13-2010 | 04:45 PM
if its stock compression ratio then you can run essentially anything you want. but thats assumming that your " little ecu" work didn't push the ignition map straight into detonation all the time ...
stevesxm is offline
Old 04-13-2010 | 11:44 PM
You should be perfectly fine with 89 octane. I have CMI's on my 502 mpi's and run 87 octane. No ecm work though.
Griff is offline
Old 04-14-2010 | 09:31 AM
Default little ECM work
Tyler Crocket did some ECM work based on me adding the EMI off shore exhaust and vortech breathers.
he said they added a little more fuel and remapped the timing curve I think and bumped my rev limiter 250 rpms since I was hitting it,
All this talk now I hope I'm ok... sure don't wax these motors they only have 200hrs...
My wife always says " when can you just leave "chit" alone...
DANG she may be right.
