Best place to get Synthetic Gear lube? >
Old 04-14-2010 | 05:44 PM
Default Best place to get Synthetic Gear lube?
I am installing a Bravo XR with Sportmaster lower and would like to know who has the best price on Synthetic gear lube. Any recomendations on brand?
Sledge Hammer is offline
Old 04-14-2010 | 05:55 PM
Throttle Fever's Avatar
I use Amsoil, have for the last four seasons. No issues found on reseal this winter. That in B1's with 600 HP in front of them. I have a local guy I usually pick up a five gallon pale from ($181.00). That way I can do my 20 drains and fills for a couple of seasons. You can look it up on the web, and find a local distributor, they are all over the country. That is my preferance. Pete
Throttle Fever is offline
Old 04-14-2010 | 06:51 PM
I can order Ouick Sliver High Performance gear oil for you. It runs about 180.00 for 5 gals.
HighPriority is offline
Old 04-14-2010 | 07:39 PM
ChristianGott's Avatar
Order direct from amsoil...right to your door/no middle man, the local rep will be your direct contact....great stuff, too..
ChristianGott is offline
Old 04-14-2010 | 08:03 PM
Default Gear oil
Just replaced twisted shafts in my sportmaster after 10yrs running Klotz in it and the gears and bearings looked great. If you get near Milwaukee I stock Klotz Estorlin synthetic Gear lube 80W/90 Hypoid. good stuff. if you want a different weight I can order. Just call me at 414-581-4300 if interested.
Thanks,
Jeff
Jeff H is offline
Old 04-15-2010 | 04:51 AM
Mr Gadgets's Avatar
Charter Member #601
I use and recommend Royal Purple 75-90 Max Gear lube.
Just my .02
Dick
Mr Gadgets is offline
Old 04-15-2010 | 06:18 AM
I second the royal purple, can get at most auto parts stores, advance, pep boys, etc.
ezstriper is offline
Old 04-16-2010 | 12:12 AM
Rebel_Heart's Avatar
I've run Royal Purple 75/90, ever since Mr. Gadget went through my drives several years ago. Just change at the end of every season.
Rebel_Heart is offline
Old 04-17-2010 | 09:21 AM
I wouldn't use Royal Purple if it was free, or Lucas anything!
http://www.amsoil.com/lit/g2457.pdf
The way I look at this test is, for someone to put this into print, they better be right about their statements!
07DominatorSS is offline
Old 04-17-2010 | 05:16 PM
35fountain's Avatar
I use Amsoil Universal marine Gear Lube in my bravo's..
http://www.amsoil.com/storefront/agm.aspx
35fountain is offline
