Crank Case Vent >
Crank Case Vent
Crank Case Vent
Old 04-14-2010 | 10:57 PM
Default Crank Case Vent
Anyone know if and where you can get a vent that replaces your oil fill cap and just threads right in. It would double as the oil fill cap and vent. Theoretically would be the easiest way to do it for me. It would be the standard Chevy type that they use on the 496.
SDFever is offline
Old 04-15-2010 | 12:50 AM
Can you just drill a hole in the stock oil cap???? Might be an option.
Griff is offline
Old 04-15-2010 | 04:42 PM
anewway's Avatar
I have the Keith Eickert valve covers, and they sell two type of thread in breathers. Well, the breather extensions
http://www.keitheickert.com/searchre...CategoryID=371
They have push in or clamp on breathers.
http://www.keitheickert.com/searchre...CategoryID=165
anewway is offline
Old 04-16-2010 | 12:16 AM
Thanks I was looking for one that is a single piece that has the oil fill threads on the bottom instead of a hose clamp...
There probably isn't anything made like what I want. Have to cut a hole in mine and make it.
SDFever is offline
