hp500 jets
Old 04-15-2010 | 05:39 AM
Default hp500 jets
OK..I know this has been asked before, but what is the FINAL answer on jetting an hp500 Carb on a single plane intake? Square jet it...or staggered? Its my understanding that the carbs came both ways. Thanks.
tinman565 is offline
Old 04-15-2010 | 12:33 PM
The Merc HP500 carbs all had staggered jetting from the factory.
There is no FINAL answer. Its all a matter of opinion and unlees you are running it on a dyno and trying to get every last bit of hp out of it, there is no way to tell for sure.
Griff is offline
Old 04-15-2010 | 05:02 PM
blue thunder's Avatar
Unless you are running a hp500 totally stock, square it up.
blue thunder is offline
Old 04-16-2010 | 06:09 AM
just finishing my .030 500 w/850 and full headers where would be a good starting point on jetting ? thanks Rob
ezstriper is offline
Old 04-16-2010 | 11:21 AM
Call holley and find out what the out of box marine 850 jetting is. Then add 5 jet sizes to those numbers and you will start a bit rich and can lean from there.
BT
