Go Back  Offshoreonly.com > Owners Forum > Banana Boat
24' Banana convert OB to inboard w/bravo >
Old 04-15-2010 | 12:30 PM
Default 24' Banana convert OB to inboard w/bravo
Has anyone ever converted a 24' banana OB (w/bracket) to an I/O? Are there any differences in the transome/stringers on an I/O vs. OB? Looking at the possibility of converting an OB into a BBC with Bravo. Appreciate your thoughts.
rvander68 is offline
Old 04-15-2010 | 09:17 PM
Air Dog's Avatar
I looked into doing it.
Here is what you have to do.
1. Close in Transom, (might as well replace it as the transoms are usually weak if it's an older boat).
2. Move the stringers closer together or run a second set of them inside the current ones, (outboard stringers are farther apart).
3. Make a new hatch to cover the larger engine compartment.
4. Buy engine, transom plate, gimble, upper / lower drive.
5. Post pics...
Air Dog is offline
Old 04-16-2010 | 12:57 PM
Stormrider's Avatar
JC Performance Engines
Do you own the OB boat already?
Cause there is an IO boat ready for engine and drive for sale here in LI... its on CL.
Stormrider is online now
Old 04-19-2010 | 10:20 AM
Chatim Racing's Avatar
and if you are going to take off the deck etc, you may want a new one from us...
Chatim Racing is offline
Old 06-08-2010 | 08:08 PM
Top Banana's Avatar
Before you rule out an outboard, why not spend the extra money and just add a couple more and have three of them like this boat.....24 foot Banana with triple 2.5 Merc's
Attached Thumbnails 24' Banana convert OB to inboard w/bravo-24-banana-w-triple-2.5-merc-outboards.jpg
Top Banana is offline
