swivel pin seal , alternative? >
Old 04-17-2010 | 06:41 PM
Default swivel pin seal , alternative?
is there anyone that has used an alternative seal for the swivel pin seal? is this a standard rubber lip seal ? I hear the factory ones are junk anyway. If i new a standard one woud work , I could finish getting my transom back together tomorrow , if not , it will be waiting on a Merc part , and not finishing until next weekend.
dookie is offline
Old 04-17-2010 | 07:36 PM
scottw's Avatar
Take the pin to a bearing place. They should be able to match you up.
scottw is offline
Old 04-17-2010 | 07:39 PM
Panther's Avatar
Frank's Marine Service
if memory serves me correctly it is a double lipped seal.... sorry I can't remember for sure...
Panther is offline
Old 04-17-2010 | 09:02 PM
It's a single lip, at least the ones on my TRS were. I couldn't get the numbers on the top of the seal to cross reference to anything common. I also surfed the Timken seal catalog on the web and could not find anything with the same dimensions.
I have two new ones on order, couldn't find a better alternative.
bustedbrick is offline
Old 04-17-2010 | 10:34 PM
I called my bearing reps from two different places today .
The best i could tell with just a scale , the measurements looked like shaft size was 1-1/16" and the bore in the housing was 1-3/8" . Neither one of them came up with anything.
I searched quite a bit this evening for threads thinking somebody else has had to have had this same trouble. I really want to assemble the transoms tomorrow and dont have the parts . THis sucks......
dookie is offline
Old 04-18-2010 | 01:08 PM
seafordguy's Avatar
External Hydraulic steering takes a fair amount of the stress/wear off that area of the Transom Assembly....
seafordguy is offline
Old 04-18-2010 | 05:30 PM
I already have the external steering , the seal has just been leaking for some time. I have pretty much change anything and everything in the back that could possibly leak. I dont know what I was thinking not buying these seals in the first place.
I honestly think i am going to try a different approach with the seal. I have not read anything good about the factory seal. I use a different type of "Isolator" in the industrial business , that i think would work great. may just have to machine the holes out just a bit.
dookie is offline
