Technical Question
Old 04-23-2002 | 06:36 PM
From: Lakeway, TX (Austin/Lake Travis) / LOTO Gravois Arm
Default Technical Question
I know that an engine block can crack from freezing. Very common type of damage from freezing without winterizing.
But can an engine block crack from overheating?
And If so, is it common for a the block to crack from excessive heat, or does it happen just sometimes (while other massive damage happens)?
And if an engine block can crack from overheating, what other damage might I look for if I suspect an overheating incident?
Thanks for your input.
dh
In2Deep is offline
Old 04-23-2002 | 07:08 PM
Indy's Avatar
Member #154
Dave...you have some head problems if it gets too hot. They can twist/warp and have to be ground flat if the damage is not too severe. This can't be for your new 496, can it Steve
Indy is offline
Old 04-23-2002 | 07:09 PM
Mr Gadgets's Avatar
Charter Member #601
I heated a cast iron cylinder head up to 400 degrees in the oven to get some wedges out. I had a big hole in one of the intake ports I wanted to get welded. The wedges were epoxied in, so I heated it to burn out the epoxy. Well when I pulled it out of the oven it must have cracked when it hit the cold air. I got to the welders and he said the thing was all cracked.. So the head was junk.. Point being that heat and cold to quick could crack it. I know that when they are welded they heat it up pretty hot.. so I figured I was ok.. but I wasnt.
Don't know it that helps, but if you got it that hot, I would suspect damage to the bores and bearings and the works.. Pull it out and tear it down.. then read what the parts are telling..
Good luck
Dick
Mr Gadgets is offline
Old 04-23-2002 | 08:00 PM
No, Steve, definitely not the new 496. It's running fine.
It's an issue with my old boat.
dh
In2Deep is offline
saulesses
Prop Talk
5
06-20-2007 07:48 AM
Ratchet
1
01-23-2004 06:19 PM
Shane
09-26-2002 10:15 AM
Shane
1
06-17-2002 01:46 PM
Shane
06-17-2002 09:40 AM
