If you were a part on my prop...what would you be called? >
Old 04-20-2010 | 11:22 PM
Default If you were a part on my prop...what would you be called?
I have twin XR drives with two Mirage Plus props. The props are in two pieces where there's this solid hub piece with four plastic "shims", four silicone-like pieces that go under the shims, and then the main prop assembly slides ontop of all that.
I need to replace the little silicone guys and can also do the shim things too. What are all those called? Is there a hub kit that includes everything all in one shot?
Thx
synack is offline
Old 04-21-2010 | 02:36 AM
c_deezy's Avatar
Sounds kind of like the HP Flo-torq hub, but a pic of what you have would help.
Is it this one?
If not, here is a whole page of different hub kits:
http://www.mertenmarine.com/servlet/...its/Categories
c_deezy is offline
Old 04-21-2010 | 06:56 AM
throttleup's Avatar
It sounds like your describing the "snubber strips" for an XR hub, part #840382A1.
Julie
throttleup is offline
Old 04-21-2010 | 11:06 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Julie's right. We have them in stock for $14.71
Thanks, Brett
[email protected]
bbladesprops is offline
Old 04-22-2010 | 02:10 PM
My boat is still in storage for another week, so I couldn't get pics.
I found an image of the hub that I have:
So it looks like the snubber strips are what I was looking for!
Thanks for the help!
synack is offline
