Lack of Power 1990 VIP
Old 04-21-2010 | 07:24 AM
Default Lack of Power 1990 VIP
I just got a 1990 VIP 18' with Ford 302 and it tops out at 47 MPH. I am happy with the way it runs but it almost drowned me to death trying to pull me up on ski. Is there something I can do to get it to accelerate and plane out faster?
chappjw is offline
Old 04-21-2010 | 08:19 AM
smaller prop or a 4blade prop you got to run your boat wide open see wt your rpms are . then you will no wt prop to get
bajabob is offline
Old 04-21-2010 | 04:01 PM
More prop blades. A Merc High Five prop will put it on plane in a few seconds.
Griff is offline
Old 04-21-2010 | 09:05 PM
Thanks, I will check out the tach nest time I'm out.
chappjw is offline
Old 05-23-2010 | 08:19 AM
My rpm are at 4400 right where they should be at WOT. Still has trouble pulling me out of the water on ski. The prop I have on is 14 1/2 x 19. Any suggestions?
chappjw is offline
Old 05-23-2010 | 09:26 AM
Did you try bigger skis?
just kidding, we have a 02 21 ft VIP we use for a ski boat with a 5 liter motor and it will pull up 2 grown men turing a 21P 3 blade prop, we turn about 5200 rpm at wot and get about 53mph, you may have a diffrenet gear ratio and need to try a lower pitch prop
Donzi Dude is offline
Old 05-24-2010 | 01:40 PM
Get a CHEVY LOL
NOPUN is offline
Old 05-24-2010 | 03:39 PM
Default Fixx
I thoughy the 302 should max out @ 5k
FIXX is offline
Old 05-24-2010 | 04:13 PM
Cheapest solution seems to be to try a 17 pitch prop.
wjb21ndtown is offline
Old 05-26-2010 | 07:29 PM
Try a 15p prop, you don't need to to go that fast to ski, just need a great holeshot.
jtmarten is offline
