Weiand 177 Blower Pulley Size >
Old 04-22-2010 | 10:43 AM
Default Weiand 177 Blower Pulley Size
Hey All,
I have a boat with a 525 SC Motor and the dash gauge is showing its making 8 to 8.5 lbs of boost at WOT (5200 RPM). From what I understand this is higher than the stock boost. Trying to figure if I have a faulty gauge or an aftermarket pulley. What is the stock diameter of the pulley in a Weiand 177 blower in the 5252SC package. The one that is on now is 3.5 inches.
Thanks in advance
Eric
Kid Cumberland is offline
Old 04-22-2010 | 11:57 AM
blue thunder's Avatar
Ok
blue thunder is offline
Old 04-22-2010 | 02:36 PM
Hey all Please don't pass up on this thread because of this answer. Thanks Blue Thunder but it doesn't really answer my question. Just looking to find out what the stock set-up was. Griff??
Old 04-22-2010 | 03:20 PM
Stock is 3.5" upper pulley and 7" lower pulley. Stock boost is 5.5#.
Is this something that just started???
A restriction like exhaust valves not opening all the way could cause a boost pressure increase. I would definately verify the gauge first before doing anything else.
Griff is offline
Old 04-22-2010 | 05:20 PM
If you have a 7" lower pulley, to make that much boost you would need a 2.85" upper pulley. A stock upper is (if my bad memory is correct) 3.25", which will make 5.5 psi. All boost numbers are assuming you don't have a chiller.
Old Navy is offline
Old 04-24-2010 | 06:59 PM
Im not sure if its something that just started happening Griff. I dont recall that much boost last fall but I only had it for a few runs. I did the top end rebuild this winter but used all stock size valves but did put in severe duty intake and Inconel exhaust. New Hydraulic lifers too. If it were and exhaust valve issue would the motor run strong like it is?
Old 04-24-2010 | 07:13 PM
I just dynoed a Hawk 525 today with a 177 Blower and stock pullies. 4.55 LBS boost at 5500 RPM.....
kreed is offline
Old 04-24-2010 | 07:22 PM
What heads?
Old Navy is offline
Old 04-25-2010 | 08:00 AM
I get about 5psi with the 3.23 top pulley, and 7" drive pulley with my 454/177 combo.
MILD THUNDER is offline
Old 04-25-2010 | 08:39 AM
Originally Posted by Old Navy
What heads?
GM iron heads. 088 castings.
kreed is offline
