Right or Left?
I've been seeing some threads about right and left props and which is best suited for this or that hull design. I just got a '94 27fever with a single carboratored 502 - Bravo 1 with a 23P Mirage Plus blade. I don't know the H.P., but it definitely isn't stock. I know I don't have enough data to ask for a specific blade size/pitch, but can anyone tell if my '94 fevers hull is best suited for a right or left prop? Thanks for any and all advice.
Once you run the boat you can make that decision. If th boat lists or hihg sides at idle and low rpm ranges, oposite rotation me be needed. Your hull is a boat that can run best with a LH rotation. It tend to be the route with big HP.
Brett
Brett
[email protected]
[email protected]
