12:1 compression ratio >
Old 04-28-2010 | 02:02 PM
Default 12:1 compression ratio
just finished rebuilding the first of two 502 engines for the cafe racer. Since there are no dynos in panama and all i have to go by is the compression ratio, was wondering what kind of hp would the engine put out considering 12:1 compression? no blowers, just naturally aspired.
CafeRacerPTY is offline
Old 04-28-2010 | 02:25 PM
Rookie's Avatar
Need a lot more info than that; Heads, cam, carbs? also @ 12:1 can you say "The Pin Has Been pulled." That is A LOT of compression in a boat engine. You running straight race fuel?
Rookie is offline
Old 04-28-2010 | 02:33 PM
Hope there is lots of GOOD gas in panama !!!!!!!!!!!!!
Jeff P31 is offline
Old 04-28-2010 | 02:38 PM
!!!!BOOM!!!!! I say way too high!
kreed is offline
bcfountain's Avatar
Registered User
Default problems
big compression like that you are asking for trouble.looks like you will be burning the realll expensive stuff.i can only imange how much race gas cost in panama.
bcfountain is offline
Old 04-28-2010 | 04:17 PM
gas in panama is 91 and 95 octane at the marina.
Old 04-28-2010 | 04:34 PM
then it doesn't matter how much it costs because you are only going to use about 3 gallons before the pistons melt.
if you are locked into 91 /95 then you better get it down to 9.5 or so or start buying pistons in bulk.
stevesxm is offline
Old 04-28-2010 | 04:48 PM
Sick Stinger's Avatar
Brotherhood #1
Yup................. Im at 9.8 and on the teeter of oh $hit.
-Mike
Sick Stinger is offline
Old 04-28-2010 | 07:39 PM
started the engine for the first time , runs nice, but on JET FUEL... guys were right. as usual. will jet fuel cut the cheese?
Old 04-28-2010 | 07:44 PM
bcfountain's Avatar
Registered User
Default octane
i would think you would need aleast 110-115 octane to support that kind of compression,maybe more.
