Basic Plug Stuff >
Basic Plug Stuff
Basic Plug Stuff
Old 04-28-2010 | 08:03 PM
Default Basic Plug Stuff
I've been going through this ritual for three years, and it shouldn't be this hard. Mercury had some trouble (so the dealers said), with their fogging oil for a couple of years. It fouled plugs. OK fine. Then they had a TSB out on the gapping of plugs, type of plugs, etc...
Fuel injected engines should have had the .60 gap versus the standard .45 gap for carbed engines. I lost a tremendous amount of rpm's after the fogging oil episode, and regained them with new plugs. As it turns out, the tech put regular plugs in, not the specified plat plugs.
Does everyone wait until the fogging oil is gone to replace plugs or clean them? I have no desire to spend $20 each for plat plugs only to see them foul.
VtSteve is offline
Old 04-28-2010 | 08:32 PM
before you fog for winter layup,install old plugs,then fog it.after you run it the first time in the spring,put the new plugs ln.i know its a little xtra work,but it will save you money.
mike tkach is offline
Old 04-29-2010 | 05:01 AM
Makes the most sense of anything. Thanks
VtSteve is offline
Old 04-29-2010 | 05:22 AM
Do yourself a favor and do some homework on the price of those spark plugs.
Just try to make sure you buy them already gapped at .60 if you can.
http://forums.iboats.com/showthread.php?t=390243
Boat Tech is offline
Old 04-29-2010 | 05:58 AM
There's even some variation if gapped from the box. Packaging counts.
VtSteve is offline
