4 blade vs 5 blade vs 6 blade (cleaver) >
Old 04-30-2010 | 08:47 AM
What are some advantages and disadvantages of these different props, say they were all the same dia and rake, pitch is obviously going to change due to # of blades. I am running a flat bottom Top Gun with 1000hp engines and #5's on boxes.... going to raise my X dia as high as possible (with the box), which prop will give me overall handling and which prop will give me TOP SPEED....
bigfarmer is offline
Old 04-30-2010 | 08:58 AM
If there is any question in your mind about propping a boat or just anything concerning props, as you may know hit up BBB blades on the board. he lists his # and is very acomadating to us boaters who dont know everything. As far as my knowlage goes is to say that a four blad may get you a better top speed and a five may give you a slightly better hole shot. I am sure you will need to provide much more info to get smart suggestions here. Hull? length? and what you are trying to acomplish. I have 16x34 4 blades and am happy with em. they spin out a little at hte launch but while at crusing speed hit the throttle and there isnt anything but a he#$ of a pull as she just goes. Try bret at BB for tech info and he will save you a ton of work.
kneeslider74 is offline
Old 04-30-2010 | 05:19 PM
Scott at Mercury Racing's prop department is my "go to" guy for rigging/prop selection issues. In my experience, the higher you go, the more blades you need to stay hooked up, but there are too many variables to be sure. Give Scott a call: 920-921-5330.
FasterFaster is offline
Old 04-30-2010 | 11:23 PM
More blades and more blade surface area translate into more stern lift.
Griff is offline
Old 05-01-2010 | 12:02 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
On a hull of your vintage, the 4 blade props will give the better speed. If the 4 blades hook up well and have a low slip number, they would be my choice because they will create the lesser amount of stern lift.
The 5 blade props will more than likely get the boat on plane quicker and can have the better fuel economy. They will lift the stern higher than the 4 blades and may create poor WOT handling. It would be interesting to try both prop sets at the low drive heights and again when you raise the drives.
FasterFaster, Scott's a good guy. I got him his job at Mercury Racing in 2003. We brought him over from the Merc main plant. I left Mercury Racing about 6 months later.
Brett
[email protected]
bbladesprops is offline
