Sea strainer locations? Pics?
Have you decided how to take care of the sand problem? I can't seem to find sand strainers at all.
As for location, when I looked at my 32 I think I would put one on the starboard side stringer, and the main stringer running down the middle. that way they would be as close to the sea water pumps as possible.
I think that i am going to drill my block off plates for a thru fitting , and attach a hose . Run the hose to my strainer with a valve. IF I know that I am coming into questionable territory I can switch to bringing water from there. (At Idle speed only) I am going to remove the boots off of the gimbal housing exhaust port ,and i think that it will get enough water from there. It may or may not work , if it doesnt , I can either pull the hose and plug the plates . Or at the end of the season remove motors and change plates completely. I have them programmed into a cnc file so I can make more with no trouble.
I can't see how you could plug it without removing the motors, but you will have more room without the y pipe.
There was the same question in the general section and someone posted a link to valves that could be operated with a dash switch. KYboy started it, you may want to do a search.
