202 Stinger Build
Hi Everyone new to the sight. but would like to share my current build, 1987 202 stinger Chris, the boat is currently all white with new interior, just installed a 2007 Volvo 8.1 with 1:78 DP drive with F6 props, just took the boat out for a test run, the boat ran very well, but i think the hull needs a few tweeks to make it even a better performing boat, lenghten the hull back to the end of the afterpods, giving the boat more lift aft and a longer running surface and a flatter on plane take off, also working on the propping of the engine to boat
combination.
Working on getting pics for your pleasure!
JR
combination.
JR
So far you are right on your asumptions,We have a 202 on the sight here,and found out the same thing the boat needs to be longer.We are in the high 70's low 80's on gps depending on how the boat want's to handel on any given day.We are running a small block chevy.Did you take the sand out of the front.To solve the problem of length,this year we went to a imco extension box,external steering and 280 K planes,we are also going procharger this year.We found the boat get's into a chine walk in the mid 60's till the low 70's but you can drive thru it,we have several you tube clips on this boat.You really have to drive these neat little rockets.I know from running drag boats that this thing has a100mph in it,Just watch it the thing will blow over on you.Will be posting pic's ect of the new changes soon.Lot's of luck. JOHN SR.
Thanks Fenderjack
About the sand in the bow, no i havent removed the sand, not yet, because of adding the extra weight aft and yes the blowing over issue, I noticed when trimming the boat out, it didn't react well to trim, so i am going to do some bottom research on the little rocket, see I have been in the product development field for the marine industery for 25 years and have worked for companys like Four Winns,Chris Craft,Larson, Glastron, Azure, and have helped developed hull bottoms for each of these companies and really enjoy taking older boats and making them run smooth stable, fast and more important quick on plane, see most companies when introducing new boats dont do enough testing before launching a new product and have a good understanding on what the customer is looking for in their boat, and the customer dont know until its to late after the purchase.
Anyhow, I have a guy that worked for me at Four Winns that can extended my hull with out to much trouble and i think the boat will run great, but i have to finish a little more testing.
Keep in touch Fenderjack
If yours is like mine it has a hook in it,I found I was never able to get the bow up to air it out,getting on plane was really never a issue with the V/8 but was with the V/6. The sand is up in the bow under that big mound of foam. We took out almost 200#.Now the boat airs out good. Thanks JOHN
Hey Fenderjack
Another thing with extending the afteropds, this will allow for alot less bow rise and a much quicker planing time, also will help prevent chine walk, the boat then will run on the after pods at full throttle and support the boat, should be nothing but air under the whole boat, should also be able to take care of the mid range porpoise.
Just ideas on how to make this little boat even better!
We will see!
John R
We will see!
John R
Mid range porposing,Don't have any never did.You might have it because of the extra weight in the rear.Our boat never had trim tabs on it,and after running this boat for almost 41/2 years I think that the addition of tabs alone might of taken the chine walk out of it.Also never had external steering and you know what a little slop can do.The chine walk is not severe and only is their for a little bit.So I think every one of these 202s are different,because there was no quality control,Just pull out the floors and look at that mess they call fiberglass work. JOHN Sr.
Thanks Fenderjack
i will start digging and testing and see what i come up with!
Thanks for all your insight!
I just may need to pull a mold set after I get this boat perfected!
JR
JR
If you could pull a mold ,are you capable of laying up a hull and deck,If so I would be VERY interested.Have sum good input as to what the boat needs.Full length REAL engine stringers for one. Thanks JOHN
