496 cooling circuit >
496 cooling circuit
496 cooling circuit
Old 05-05-2010 | 04:45 AM
Question 496 cooling circuit
I'm going to change the impeller on my raw water pump before hitting the water, and a doubt popped to my mind.
How does the water in the closed cooling circuit moves around? Is there another impeller somewhere, which I should consider replacing?
Thanks in advance!
mapism is offline
Old 05-05-2010 | 06:28 AM
Thanks in advance!
water pump in front of the engine driven by the serp belt,does not have to be replaced
boatnt is offline
Old 05-06-2010 | 01:57 PM
Thanks for your reply.
Do you mean it doesn't require any kind of periodic check or maintenance?
mapism is offline
Old 05-06-2010 | 02:08 PM
tony davis's Avatar
Nope, it's a circulating pump, with no serviceable parts. with proper coolant it'll probably last a lifetime.
tony davis is offline
Old 05-06-2010 | 05:22 PM
Paul, the raw water pump you are asking about is down on the bottom of the starboard side of the engine right behind the old style fuel filter that spins on if you have that...
It's serviceable by way of removing the belt and the pump. It uses a standard Bravo Impeller and o-ring kit. If the pump is scored badly, you may want to purchase the whole pump. Otherwise, it's an easy deal.
If you are referring to the closed cooling "circ pump", that is not serviceable and will last a long time. Mine finally failed at around one thousand hours and it just leaks from the wheep hole. It would be a tough fix in your boat. If it's not leaking antifreeze, leave it alone as you're fine.
Cheers!
jt
SDFever is offline
Old 05-06-2010 | 05:26 PM
Default Very Important!
If your circ pump (closed cooling pump) every does fail, do not buy a standard automotive pump. The Merc pump has a totally different style brass impeller and it moves a much larger volume of coolant than the one from an automotive store. And of course, the one from Merc is about twice what they get from the Chevy Dealer. I think it retails for around $539.
SDFever is offline
Old 05-06-2010 | 07:06 PM
Thanks guys, yep, it's the circ pump I was wondering about, 'cause I knew nothing about it.
For the raw water pump and its impeller, I already learned a lot from this previous thread !
mapism is offline
Old 05-06-2010 | 07:25 PM
496 takes a different impeller than those on the standard BBC bravo setups (454, 502, 500HP, 500EFI, 525, etc). It is longer and not as big of a diameter, if I remember right.
bob_t is offline
Old 05-06-2010 | 07:36 PM
And it is a major pain in the a$$ to change if your engine compartment is tight. A 10mm racheting wrench will save you a ton of time and possibly some bruises to your forearm and shoulder....
low_psi is offline
Old 05-06-2010 | 08:13 PM
The center bore, where the pump shaft goes, on the 496 impeller has two flats. The standard Bravo impeller has only one flat... "D" shaped.
Also, the pump housings are brass... most of the time, the whole pump is junk. Putting an impeller in a badly scored housing is an excercise in futility.
cubicinches is offline
