K.K. Trim tab (install)
I just bought a set of KK tabs and pumps. Is there an adapter that goes from the pump lines to the SS threaded tubes that go through the transom? Just wondering what parts I might be missing. All I have are the tabs, mounting plates & cylinders (all attached), pumps and oil lines.
Thanks,
John
Also any idea of how to remove the Gel and Fiber Resins from the back of the mounting plates? It looks like they had to of been bonded pretty good. I would assume grinding it off is the only solution however thought I would ask. I just hate to grind anything beyond the original plate backing.
Thanks,
John
