2006 13' Hotdog boat and trailer >
Old 05-06-2010 | 03:24 PM
racer-x6's Avatar
Default 2006 13' Hotdog boat and trailer
Thinking about selling my 2006 Hotdog boat with the trailer. I sold the motor this winter so it does not have a motor or controls, everything else is still rigged. All the graphics can be remove easy and I can put anything you want on it. I bought and rigged it thinking it would be fun but can’t find the time or interest to do anything with it. It has a 12 gallon fuel tank, battery, trim tabs, cockpit cover, tachometer, Dino wheel, electric trim/jack plate, etc.. Don’t know what to ask for it but I have about 8k in just the boat/Rigging and the trailer. I can re-rig it with any size new motor (Mercury or Tohatsu). I originally had a 25 Mercury on it and ran it 3 or 4 times, I then put a 40 Mercury on it and ran it 2 times.
Attached Thumbnails 2006 13' Hotdog boat and trailer-hotdog1.jpg   2006 13' Hotdog boat and trailer-hotdog4.jpg   2006 13' Hotdog boat and trailer-hotdog2.jpg
2006 13' Hotdog boat and trailer-hotdog5.jpg   2006 13' Hotdog boat and trailer-hotdog6.jpg
racer-x6 is offline
Old 05-16-2010 | 02:16 AM
how could i put a hayabusa motor in it? drive-wise? whats bottom line cash for hull and trailer no motor
kilrbusa is offline
Old 05-17-2010 | 07:05 AM
racer-x6's Avatar
don't know how you would do that? I would take 4k for it as is.
racer-x6 is offline
Old 05-17-2010 | 07:54 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
What speeds did you get with each motor?
I have a 25 on mine and am shopping. I have a 75 at home, but it might be a bit sketchy!
Sydwayz is offline
Old 05-17-2010 | 08:16 AM
racer-x6's Avatar
low 30's with 25 and mid 40's with the 40, if i don't sell it I am going to put a 50 Tohatsu. the F40 was 213# and the 50is only 206# EFI with power trim, I will replace the trim plate with just a jack plate and save about 25#. the big issue is the weight, the water line was close to coming over the back.
racer-x6 is offline
Old 05-17-2010 | 06:35 PM
I know there is a small boat manufacturer that hhok Harley Davidson motors to the small Mercury vasor drive. probably could do it with a busa motor too if you have some good fab skills
tx911 is offline
