staggered vs side by side, with same hp what is MPH difference???
say same boat, same engines. both boats are dialed in the best they can be. what is the difference speed wise?????????
nah im just trying to figure out how dialed in my boat is compared to when they raced it in staggered configuration........it has about the same HP, maybe weighs a couple hundred pounds more right now with the interior
Donzi Comps all went staggered after the initial ones (built mostly for F-2 racing). Definitive speed increases, not sure exact numbers. My understanding is that staggering the motors moves the drives closer together and thus creates more of a singular thrust toward the center of the boat. By staggering the motors it also provides better balance by moving the one motor forward and putting them both lower into the bottom of the V. It does make working on them in the bilge much easier too!
It is a little more difficult docking because the drives are more centered and not as far apart but if you throttle up the reversing side to compensate for the forward overpowering, it works just fine.
