Trim Tab fluid
Old 05-07-2010 | 04:27 PM
Default Trim Tab fluid
All
I have a Baja that has IntraTrim leveling tabs. I need to add some fluid but InstaTrim wants $18.95 per PINT - that is PINT for some biodegradable fluid. That's insane - I don't care if it is biodegradable or not.
So has anyone used anything thing else instead of this overpriced snake oil they are selling?
rsscoggins is offline
Old 05-07-2010 | 04:57 PM
Transmission fluid
89Mach1 is offline
Old 05-07-2010 | 08:29 PM
I use 500 hydraulic fluid.
capt2130 is offline
Old 05-07-2010 | 08:40 PM
89Mach1 - Seriously, tranny fluid - have you successfully mixed it with the crap that is in there without fear of separation or damage?
Capt2130 - what exactly is 500 Hydraulic fluid? Can I get it at Napa or AutoZone? Have you mixed it with the OEM stuff without issue?
Old 05-07-2010 | 09:24 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I have tranny fluid in mine. Try to flush out all the old fluid so not to have 2 types of fluid. Might even remove the tank and flush it out too.
Read ' to bleed' http://www.insta-trim.com/install.html
US1 Fountain is offline
Old 05-08-2010 | 06:44 AM
Capt2130 - what exactly is 500 Hydraulic fluid? Can I get it at Napa or AutoZone? Have you mixed it with the OEM stuff without issue?[/QUOTE]
I use it in all my hydraulic machine equipment. press brakes, pines benders, etc. I get it from one of my oil suppliers. You may try any farm equiment supply company if you dont have access to a oil supply company.
When I installed my pumps they were empty. But I would drain the old before I added anything new. Unless it is the same product.
capt2130 is offline
Old 05-09-2010 | 11:33 PM
[QUOTE=rsscoggins;3104927]89Mach1 - Seriously, tranny fluid - have you successfully mixed it with the crap that is in there without fear of separation or damage?
Seriously- Yep. When I installed my tabs that's exactly what I used, and I'm sure many others on here have cause I read it on here. Granted they were new lines and a used pump that was empty, but yep, seriously.
89Mach1 is offline
Old 05-10-2010 | 06:06 AM
mine had ATF when I got it...
ezstriper is offline
Old 05-10-2010 | 02:14 PM
Strip Poker 388's Avatar
Rob
same here
Strip Poker 388 is offline
Old 05-10-2010 | 03:03 PM
Tranny fluid here to.
whoya is offline
