Go Back  Offshoreonly.com > Owners Forum > Powerplay
25 pp with 5-1/2 setback engine height >
Old 05-08-2010 | 09:13 PM
kds
Question 25 pp with 5-1/2 setback engine height
i just put on a pair cmc jackplate on my 25pp with twin 300x's and sportmaster lowers. the low water pickup on the sportmaster is 2 inches below the flatspot. can anyone give me an idea of how high u think the prop shaft should be above or below the flat spot on the transom. right now the prop shaft is about 3/4 inch below the flatspot but i think it should be a 1/4 inch above or even with the flat spot with the jackplates on. i am running some 26bravos. the slip is 21%, can i have some suggestions please . my rpm is at 6700, what do u think about props . bigger or labbed props etc, as i said b4 suggestions please. thank you
kds is offline
Old 05-10-2010 | 01:17 PM
Wally's Avatar
Were doomed!
kds, your probably not going to get much help on this site...most guys are I/O here. I would post it over on screamandfly.com they would help you no problem...
-Wally
Wally is offline
