wont pass 1500 rpms and pops all over the place.
the problums started two weeks ago.
the motors wouldn't pass 4000 rpm and lots of back fires took to shop. the timimg had retarded 24 degrees. wow what a problum i thaught it had gone oout of timimng. set back on timing . put in water and it pops allover the place when trying to go past 1500 rpm
whaat is happing. could it have jumped timing or cam broke ..
seems like it out of timing.. what can it be.
what happens if the cam moves..
helpppppp
helpppppp
helpppppp
helpppppp
What he said. If they do line up, pull the timing cover and check the marks on the crank and cam gears.
If the boat was running fine, then out of nowhere lost power, ran rough, etc, would make me think timing chain jumped
Pull the coil wire off and turn over the engine. If it turns over smoothley, then the engine is OK. It will be a dampner, or something else that has let the timing move around.
Also you are leaving out an imprtant piece of info.
Does the engine rev smoothley while it is on the trailer on in neutral??
If it is only generating problems under load, then it is either fuel of fire.
Do you have MSD ignition?
Check the MSD box??? Balancer???? If the engine is running good in neutral, and turns smoothley when not firing, it is not catastrophic. It is on the outside
