1.36 vs 1.50 bravo >
1.36 vs 1.50 bravo
1.36 vs 1.50 bravo
Old 05-10-2010 | 08:00 PM
Default 1.36 vs 1.50 bravo
i had a 1.50 ratio bravo 1 stolen and found a nice 1.36 ratio bravo 1 drive,question is how much will that change the RPM needed to turn the same prop.
Can I correct by using a diff pitch prop?
Its on a late model 21ft ski boat with a 350 mag 300Hp.
Thanks for any help or suggestions!
hiline is offline
Old 05-10-2010 | 08:15 PM
You can correct it with a prop. You would need to go down 2" in pitch...that will get you very close. Use this:
http://www.go-fast.com/Prop_Slip_Calculator.htm
JRider is offline
Old 05-10-2010 | 08:23 PM
jeff32's Avatar
only 2?
jeff32 is offline
Old 05-10-2010 | 09:08 PM
Ok great thank you.
Looks like a 450 rpm drop so 2-3 degree in prop change.
Thanks!
hiline is offline
Old 05-10-2010 | 09:14 PM
Thats what the calculator says...Reality may be different. Usually you dont go to a higher ratio until you have ran out of prop pitch in a given line of props.
JRider is offline
Old 05-10-2010 | 09:23 PM
Default fixx
the only down side will be you may loose acceleration,how fast your boat use to go to a certain mph may be a little longer time to get their..Also you may loose the spap from the engine's power..
FIXX is offline
Old 05-11-2010 | 02:13 AM
For a ski boat and that engine combo, I would not use a 1.36. Its most likely about a 600rpm/3" pitch difference.
Griff is offline
Old 05-11-2010 | 09:19 AM
I went from a 1.50 to 1.36 and went from a 32p bravo to a 28p bravo. Also I have an almost new bravo 1 upper and two xr lowers that are 1.50 with DWP for sale if interested.
indywhsle is offline
Old 05-11-2010 | 02:25 PM
how does your boat run compare to the 150 to the 136 ???
bajabob is offline
Old 05-11-2010 | 03:56 PM
JasonSmith's Avatar
Not as well as mine!
I don't think Mike will know & neither will I. We both changed TONS of stuff, including the drive heights & gear ratios when we re-powered.
JasonSmith is offline
