Whipple on 6.2
Old 05-12-2010 | 05:21 PM
Default Whipple on 6.2
Looking at a 32 Sunsation MCOB with a whipple on each of the 6.2s.
Would a survey determine how many hours and at what rpm those engines were driven since the whipple installation? ie.. does the ecm get wiped when a whipple is installed?
For arguments sake, if the engines were not driven hard, and maintenance was by the book, how long would 6.2s last with super chargers?
thanx
bert4332 is offline
Old 05-14-2010 | 09:45 AM
A computer can tell you what use the current PCMs have. They may have replaced the ecms when the whipples were installed though. Life just depends on how hard they were run and fuel quality. The weak link is the cast pistons. They hold up fine as long as you have good fuel and don't run miles long wot runs. Get some low octane fuel and they're done.
Bob
Full Throttle Marine
Spicewood, TX
thanx
bobl is offline
Old 05-14-2010 | 10:14 AM
Knot 4 Me's Avatar
Another thing I would look for is to see if they installed oil coolers when they installed the Whipples. Those 6.2's only hold 4.5 quarts of oil IMO, an oil cooler is a must if you add a Whipple.
Knot 4 Me is offline
Old 05-14-2010 | 10:18 AM
Cat & Mice's Avatar
X2 on the oil cooler. I had some 6.2 with Whipples and we added 10 qt pans and ran the piss out of them. They lasted way longer with way more boost then I would have guessed. If you have enough oil and it stays cool then they should last for a long time. Well also given that they get the proper fuel octane for the boost setup.
MP
Cat & Mice is offline
Old 05-14-2010 | 11:50 AM
Just my 2 cents but I would hold out for one with 496's unless the price was just unreal.
TampaBeach is offline
Old 05-14-2010 | 08:59 PM
Have the pcm checked, it will tell you everything you need to know.
bunbuster is offline
Old 05-15-2010 | 07:43 AM
Indy's Avatar
Member #154
I'd check out threads by UncleToys from a few years back, reading what he went through with Whippled 6.2s will give you second thoughts.
Indy is offline
Old 05-15-2010 | 09:06 AM
MP
Who's oil pan did you use, or were they custom? Did you just increase capacity and no coolers? Thanks.
4mulafastech is offline
