ignition timing 98 mfi 7.4
i have a 98 7.4 mfi 310 hp and i need to know what the timing should be set at and is there anything you need to disconnect like when you set the timing in the trucks thanks Ed
You short the A and B terminals on the diagnostic connector, this puts it in base timing mode. Then most engines get set at 8 degrees BTDC. My balancers actually have an 8 degree line highlighted.
