livorsi PFLS24 sending unit proper wiring configuration >
Old 05-16-2010 | 09:19 PM
Default livorsi PFLS24 sending unit proper wiring configuration
Is anyone familar with the Livorsi PFLS24 sending unit. I sent my boat to Skater to have tanks redone and the hot and sending wires are on the same terminal and one ground wire is off (see photo 1). The other side has completely different sending unit which is wired correctly (see photo 2)
Thanks,
Sam
Attached Thumbnails livorsi PFLS24 sending unit proper wiring configuration-sam-cam-672.jpg   livorsi PFLS24 sending unit proper wiring configuration-sam-cam-674.jpg
skate is offline
Old 05-17-2010 | 10:12 PM
Default Got my answer from the man today to good not to share
Sam,
Just connect the black wire to the ground. If it blows, you’ll be in a better place any way.
Pete
skate is offline
