parts for sale-flywheel, oil filter bracket.... 454/bbc parts >
Old 05-18-2010 | 11:49 AM
Default parts for sale-flywheel, oil filter bracket.... 454/bbc parts
i have a flywheel form a 89 330hp 454-100 firm
oil filter bracket from same motor- make offer
weber/edelbrck style throttle cable bracket-make offer
2 roller cams from non mag 454 mpi motors, 99 models-75 each
complete springs, retainers, locks, spacers, stud assembly and rockers from a 99 454 non mag mpi 454 to match above cams. 65 bucks
99 model crank, rods, pistons from a 99 model non mag 454 mpi-200 for all or will seperate
89 330hp 454 stock iron intake manifold- make offer
2" purple fuel fill with flip up top-30 bucks
would trade for k plane pumps and hoses, purple parts, drive indicator bracket for bravo drive, lounge seats for cuddy if they will fit... also looking for a cheap gen vi 454 or 502 block, all it needs to have is main caps but bare otherwise
regalman4925 is offline
Old 05-18-2010 | 12:02 PM
Default 454
i have 1 for sell do you have a contact ##
ridefast77 is offline
Old 06-29-2010 | 12:01 PM
Ttt
Old 09-18-2010 | 11:48 AM
bump contact number is four zero two 630-4310
would like to get the shop cleaned up a little
Old 09-18-2010 | 12:03 PM
I have a genVI 454 mpi long block that has heads and everything that I would sell for $500 plus the frieght, but I really don't need to trade for anything. It needs a tear down. Lost oil pressure, so we replaced the whole long block
jeff1000man is offline
Old 09-18-2010 | 12:05 PM
is that a mag or standard mpi? i may be intersted but need to move some parts first.
also not listed i have a 89ish complete bravo gimbal assembly minus the trim cylinders- 600 obro
Old 09-18-2010 | 12:07 PM
It was mag
Old 09-18-2010 | 03:00 PM
I will take the throttle bracket if you still have it
Sunrocket24 is offline
