Tandem Axle steel trailer >
Old 05-19-2010 | 05:31 AM
TomFTM's Avatar
Default Tandem Axle steel trailer
I have a performance marine steel trailer that will be available for sale next week. The trailer was with my activator that I'm selling but the buyer does not need a trailer. The trailer will be in Florida . (Boca Raton area) as the boat will be transported down there . The trailer has some surface rust . Trailer has new disk brake actuator , brake lines and disk brake 's on front axle. trailer has aluminum rims and radial tires. The trailer has fixed bunks and must be adapted for your boat . trailer rating in app. 5000lbs. Its a 1998 . $700.00
Tom 516-805-2253
TomFTM is offline
Old 05-20-2010 | 11:43 AM
TomFTM's Avatar
trailer will be down in Florida , Tuesday or Wednesday of next week .
TomFTM is offline
Old 05-20-2010 | 08:56 PM
rchevelle71's Avatar
Tom,
I have no use for the trailer, but if you need some help moving it around, I am local and will help out.
Rick
rchevelle71 is offline
Old 05-21-2010 | 12:45 AM
still have it?
GTOFFSHORE is offline
Old 05-21-2010 | 02:20 AM
Are those 6 lug wheels and torsion axles ???
Then i may take it !!!!!
DareDevil is offline
Old 05-21-2010 | 06:49 AM
TomFTM's Avatar
trailer is still avail. it has 5 bolt lugs, and leaf spring axles.
TomFTM is offline
Old 05-21-2010 | 03:14 PM
TomFTM's Avatar
need this thing gone ...by the way the trailer is a 1998
TomFTM is offline
Old 05-21-2010 | 04:54 PM
Wheel size/tire spec? What kind of paperwork for the trailer? Here in FL, if it weighs 2k lbs or more it needs a title. Not sure how an out of state transfer would go.
handfulz28 is offline
Old 05-22-2010 | 01:50 AM
TomFTM's Avatar
tire size 205/75/14 each tire rated at 1750lbs . The trailer has a transferrable ny reg. which works as the title. Tom
TomFTM is offline
Old 05-22-2010 | 10:50 AM
Florida only needs title if the trailer itself weighs more than 2000#, not what it is rated to carry. Tom, I'll call you later, I am at work right now. If anyone in FL wants it, I may be able to deliver after it arrives in FL.
Rick
