XR DRIVE 1.50 dwp (many new parts) $5K >
Old 05-19-2010 | 10:37 PM
t500hps's Avatar
21 and 42 footers
Default XR DRIVE 1.50 dwp (many new parts) $5K
XR drive.....1.5 DWP (w/new parts)
Last winter I replaced slightly pitted gears in the upper. 5 hours into the spring I cracked the upper case from overtrimming trying to idle into shallow water (cracked along spanner nut at input shaft). Ended up buying a new upper case, new bearings, new seals, re-used those virtually new upper gears. Lower was stripped, primed, painted, and clear-coated before re-assembly. Lower is a dual water pick-up. Original case was only cracked at input shaft but ruined. Once repaired, this became a spare sitting in the garage. The drive is a 2003-2004 vintage with under 200 hours.
$4,500.00 pallet shipped
8O4-9I4-2628
boatfan (at) comcast (dot) net
Russ C.
pics to come........
t500hps is offline
Old 05-19-2010 | 10:42 PM
t500hps's Avatar
21 and 42 footers
pics.....
Attached Thumbnails XR DRIVE 1.50 dwp (many new parts) K-entire-xr-drive-b-reduced-.jpg   XR DRIVE 1.50 dwp (many new parts) K-xr-drive-front-top-reduced-.jpg   XR DRIVE 1.50 dwp (many new parts) K-xr-drive-rear-reduced-.jpg
t500hps is offline
Old 06-07-2010 | 11:54 AM
t500hps's Avatar
21 and 42 footers
lowered price above......
t500hps is offline
Old 07-17-2010 | 03:30 PM
still available?
Baja525EFI is offline
Old 07-17-2010 | 08:49 PM
t500hps's Avatar
21 and 42 footers
Originally Posted by Baja525EFI
still available?
Yes...really haven't pushed trying to sell it but it is in the way. Still sitting in the exact same spot from when the pics were taken.
t500hps is offline
Old 09-16-2010 | 05:37 PM
t500hps's Avatar
21 and 42 footers
Ttt
t500hps is offline
Old 09-26-2010 | 08:27 PM
t500hps's Avatar
21 and 42 footers
ttt
t500hps is offline
