496ho constant beep >
496ho constant beep
496ho constant beep
Old 05-20-2010 | 01:44 AM
Default 496ho constant beep
I have 2007 mercruiser 496ho, when i accelerate to 3000rpm the engine sound constant beep and loss power if i keep it down to 1200rpm beep go away, i check my water temp is 170, oil pressure is 25psi. does anyone have this exper. thank you
dannycommander is offline
Old 05-20-2010 | 11:06 AM
It is going into gardian mode. You need a scanner to check for sure. Impeller, exhaust sensors? You just dont know without one.
22 DAYTONA is offline
Old 05-20-2010 | 11:07 AM
Drive lube resevoir low? Water pressure sensor (bad impeller).
Busta is offline
Old 05-20-2010 | 11:46 AM
Default scanner
Hi Daytona i have twin 2001 496 HO in 28foot pantera can you tell me where best to buy the scanner i would need .no ploblems as yet but like to be ready. thanks for any help you can give me regards paul
paul buckner is offline
Old 05-20-2010 | 01:37 PM
Dave M's Avatar
Veteran: Navy
http://www.rinda.com/marine/marine.htm
Dave M is offline
Old 05-20-2010 | 01:42 PM
Originally Posted by Dave M
Thats the one I have. If you start having problems, you can get your own codes and someone here on the boards can help you. It has worked for me more than once.
Good luck Mitch
