Question for the carb Guru's >
Old 05-20-2010 | 03:55 PM
Default Question for the carb Guru's
I need to pull the trigger on a carb for my engine. Its a 439 bbc with a target hp of 530-550 hp @ 6000 rpms. I'm using the new AFR 265 ovals with a weiand stealth manifold, stainless marine exhaust, and crane ignition. Bob Mandara is doing the roller cam and has me pretty much talked into a prosystem carb.. The only issue is $$$$$. I can get a nice used HP 950 for about half the price. So my question is, would a Holley HP 950 be a could carb for this set up? If not what would you guys suggest. What kind of difference am I going to see with the prosystem vs the Holley? The prosystem still isn't out of the picture but I'd like to get on the water sooner than later.
endeavour32 is offline
Old 05-20-2010 | 04:07 PM
offthefront's Avatar
950 seems too big .... what size did Bob Spec? He would know ...... .02
offthefront is offline
Old 05-20-2010 | 04:45 PM
Airpacker's Avatar
I cant see needing any more than 850 max or the venturi velocity is going to suffer.
Airpacker is offline
Old 05-20-2010 | 05:09 PM
The reason I say an HP 950 is that the way they are rated its closer to an 830 non HP holley or am I wrong on this. Bob didn't spec anything, he just said what i had was to small (780) and that he really likes pro-system carbs. I do agree that an 850 would be right but like I was saying above holley rates the two carb different. I believe one is a wet flow rating and the other is dry, so its confusing- an 850 in one isn't an 850 in another.
Old 05-20-2010 | 07:34 PM
Rookie's Avatar
If you look at the thread I posted a couple weeks ago. JimV (Valako race Heads) and I flowed a Holley HP 950 against my old school Holley Barry Grant 750's. On the flow bench my 750's flow more % of air than the HP 950. My 750's supported 590HP on my 468 and I could have used a bigger carb. If you can only afford the HP 950 right now, get it and upgrade later. If you can borrow the HP 950 and plan on dynoing, bring them both and find out if it's worth it. I used my 750's cause that's what I had. A carb change is the easiest thing to change when upgrading power.
I also am using the Wieand Stealth and really like it.
http://www.offshoreonly.com/forums/g...-saturday.html
Rookie is online now
Old 05-20-2010 | 08:44 PM
That was an interesting test. I was going to run a 780 holley that getrdunn has. I may still grab it and test it on the dyno and see what I come up with. A prosystems carb would be cool but I've just completely restored my formula and the money tree is running a bit low.
Old 05-20-2010 | 10:03 PM
I'm running aprox. 600hp with a holly 800 double pumper
firehawkcat is offline
Old 05-21-2010 | 06:11 AM
the 950 should work well, as it's not a 950cfm, common misconception....
ezstriper is offline
Old 05-21-2010 | 09:54 AM
What size is your engine?
Old 05-21-2010 | 10:25 AM
Rookie's Avatar
Are you going to dyno this engine?? I am real curious about the those heads.
