Water temperature for 6.2 liter mercruiser >
Old 05-20-2010 | 09:43 PM
Default Water temperature for 6.2 liter mercruiser
Hi does anybody know what the water temp should run at on my 29 powerquest with 6.2 Merc's? Are the impellers easy to change on the water pumps? Thanks!!!
bthurman0816 is offline
Old 05-20-2010 | 11:15 PM
My 6.2's run right at 158-160°F fully warmed up. Impellers are easy to change if you pull the water pump off the engine.
4mulafastech is offline
Old 05-20-2010 | 11:54 PM
Expensive Date's Avatar
Mine always run about 170 the pumps are not hard to take off.Lossen the belt take off the two hoses going to the back of the pump.They can be stuck on there after the clamp is off just twist back and forth.Then there are two bolts abouve the pulley one is a nut on a stud on my motor.On one of my motors I have to lossen the bolts on the fuel pump to get pump out.
Expensive Date is offline
Old 05-21-2010 | 07:52 AM
jln
my 6.2 has a gen 3 fuel box sitting on top of the water pump and i just tried to get the water pump out and i could not even see or reach the back of the pump. so i thought i would let a merc. tech handle it. not sure if all 6.2 s have a gen 3 fuel box .
jln is offline
Old 05-21-2010 | 09:01 AM
Thanks guys for the posts!!!
