questions for u fellas >
Old 05-21-2010 | 09:43 AM
Default questions for u fellas
i have a 25ft outlaw, it had a 7.4 mpi in it, the block is cracked so i want ur adivces on what i should go with...
ive talked to a dealer about doing motor work, these are the options they gave me..
can put a 7.4 block back in for me and cost is like 5000 for block plus labor on getting all sset up. or i can get a 383 complete turn key plug and play for 9500. or i can get the black scorpion 400 hp for 12000, and then he said a 496, 375 hp for 12500... what would be my best option.. i have not heard much about the 383 but i know a few ppl who have them and they like them... would that be enough power for my boat.. thanks for your input i appricate it
scott from NY
skuttle2525 is offline
Old 05-21-2010 | 10:08 AM
Ebay Ed's Avatar
i have seen new 502 long blocks for around $7000 or so which is what i plan on doing if i have any engine issues unless i decide to find a 502 short block and build it up myself
Ebay Ed is offline
Old 05-21-2010 | 10:28 AM
Look in classifieds on here theres 502's and 454Mag's. A 383 is a smallblock. I would go with a 454 Mag if you can find a low hour used one complete.
Irishtornado is offline
Old 05-21-2010 | 10:29 AM
Stay away from the small blocks IMO.... You are better off with a 454/502 that you can build IMO. No substitute for cubic inches.....gotta make the TQ to move the glass with the deep V....
HOSSMAN is offline
Old 05-21-2010 | 12:10 PM
as hossman said put a big in !!! were is the crack at??
bajabob is offline
Old 05-21-2010 | 12:24 PM
Blow It Up, Then Pull The Plug
Sin_or_Swim is offline
Old 05-21-2010 | 12:40 PM
I think Smurfonaboat just swapped his 454mag out for a 500hp see if you can contact him. Depending on what you want to spend he may let it go for a good price and get you back on the water.
TampaBeach is offline
Old 05-21-2010 | 03:41 PM
If I were you I would either:
1) Buy a new Gen VI 454 std. bore block and put all of your old components back into it; or
2) Buy a complete motor from the swap shop, and sell your old EFI/ignition system.
Either way I'd tend to think that the total repair shouldn't cost much more than $5k.
wjb21ndtown is offline
Old 05-24-2010 | 06:53 PM
JasonSmith's Avatar
502 longblock. Put in a cam & have the ecm tuned.
I say longblock because you'll get fresh heads for a few bucksmore & your 7.4 heads suck. No other way to put it.
JasonSmith is offline
