1979 pantera merc trans inspection or rebuild?
looking for someone in the metro Detroit area that builds these transmissions. boat is set up for a 330hp 454 & trs drive. i have three of these transmissions in the garage and would like to build one good one. any help would be great.
The transmission fits perfectly in a 18x18x18 box and UPS ships virtually anywhere in the contiguous U.S. for around sixty dollars @ seventy six pounds.....If entertaining an overhaul, modifications should be made for oil pressure containment, and cooling.
I don't know how mechanically inclined you are but to rebuild one of these transmissions is about equal to rebuilding a Briggs & Stratton lawn mower engine. There is only 2 gaskets in them which you can easily make yourself. The o-rings and seals can usually be found locally at a bearing supply house as well as the bearings if needed.All the one's I have rebuilt if the fluid had been changed regularly the bearings were fine. The clutch friction plates and steels are from a Ford FMX transmission which can be purchased new on the internet for about $20 total. The complete instructions on rebuilding one is only like 12 pages and can be found in the mercury manual #2 which you can download for free.With a little imagination it can be done without any special tools. I have done several of these with 100% success and usually for under $100.
By the way what problem are you having with yours?
