Correct Engine Oil w/Roller Cam
I read an article several months ago about the danger of using Synthetic Oil with roller cam engines ,something about it's too slick ,and the roller lifters will not roll but wear flat spots, does anyone have advise or proof of this, I don't want to ruin my cam. Thanks.
Break it in on Mineral, then run good syn oil. Powerboat Mag had an article a few years back claiming that syn was too slipery. Its BS. If it was wrong, I'd guess that the ZO-6 and ZR-1 Vette's that come from the factory with it wouldn't have it.
DO NOT USE SYNTHETIC OIL ON ROLLER CAMS....
its to slick and the rollers can slide and cause wear !
I only use valvoline VR 1 racing oil on a roller ! Never had a problem !!!!
I did use Mobil 1 before and it wore the cam and rollers !
If you took out a cam and lifters it wasn't due to Mobil 1. As stated above, if its too slick to turn a roller, it's way too slick to cause wear. You had a lifter failure. I have run mobil 15w50 in my roller cam boats since 1996. No issues except when walmart runs out of 5 qt jugs.
Nearly every premium engine in cars gets M1 for a factory fill. all of them are roller cams.
NOW if we're talking M1 starting oil leaks conventional didn't, I agree with that.
[img][/img]
[img][/img]
