Wiring Diagram for 9 pin Merc engine harness?? >
Old 05-26-2010 | 04:02 PM
tomtbone1993's Avatar
Default Wiring Diagram for 9 pin Merc engine harness??
Any one have one they can post? I am looking for the engine harness. Thanks, Tom
tomtbone1993 is offline
Old 05-26-2010 | 06:15 PM
boatman22's Avatar
Sorry Tbone...I forgot....here is a link:
http://www.cpperformance.com/Instruc...olor-codes.pdf
boatman22 is offline
Old 05-26-2010 | 06:17 PM
boatman22's Avatar
http://www.cpperformance.com/Instruc...ng_Harness.pdf
Old 05-26-2010 | 06:27 PM
Thanks....T
Old 03-06-2011 | 09:29 AM
Sick Stinger's Avatar
Brotherhood #1
Is there any better of a diagram other then just the wording like a pic or something?
Doing a TRS some one hacked into the harness trying to get it right.
-Mike
Sick Stinger is offline
Old 03-06-2011 | 10:50 AM
Rookie's Avatar
-Mike
Color codes are all the same for non-EFI engines.
http://www.boatfix.com/merc/Servmanl/18/18E4R2.PDF
Rookie is offline
Old 03-06-2011 | 05:27 PM
Brotherhood #1
I have a Purple with yellow tracer I cant seem to fine on any diagram but looks factory Merc. From the bends and curve seems to go to the R side of the starter. Im running an MSD and all Autometer Marine gauges. Also MSD Dist. and Blaster 3 coil
-Mike
Old 03-06-2011 | 09:09 PM
Rookie's Avatar
I believe that wire is for sending voltage to an electric fuel pump when starting. That bypasses the low oil pressure switch on the back of the block.
Rookie is offline
