Ignition Fuse >
Ignition Fuse
Ignition Fuse
Old 05-26-2010 | 10:57 PM
Default Ignition Fuse
Does anyone know where the ignition fuse might be located on my Cigarette?
1995 Cafe Racer
Bajaoutlawd is offline
Old 05-26-2010 | 11:08 PM
Default Fixx
1995 Cafe Racer
check the main 7 or 9 pin plug on the engine,it may have a loose pin that supplys the ignition its power..
FIXX is offline
Old 05-29-2010 | 11:30 PM
Default Problem Solved
If anyone is interested Cigarette does not use fuses.
While taking a break Friday from the sun in Southern California I turned on the cabin lights at the bank of switches in the cabin. That is when I noticed a breaker labeled port and one labeled Starboard. The port was in the off position. WHile cleaning the cabin one of three people doing the cleaning, me being one of them, must have switched it off. Turn it on and all is well.
Thanks for the help.
