Question on Bravo outdrive clamping screws >
Old 05-28-2010 | 09:56 AM
Default Question on Bravo outdrive clamping screws
On the gimbal ring there is 2 lock nuts on the top. I think they call them clamping screws. It is to tighten up the upper swivel shaft. What is the torque on a Bravo in ft.-lb? Also is there any danger in retorquing them? I only ask because I heard that you can crack the gimbal ring in doing so. Should they be torque checked every year? I have very loose steering and this was one of the thinks I was told to do, it may help some what?
mslitti is offline
Old 05-28-2010 | 12:22 PM
If it's real sloppy, tightening it will probably just
break the gimbal ring...the gimbal ring is worn out.
Here's the torque spec's out of the latest manual
3/8" u-bolt 53 ft/#'s
7/16" u-bolt 70 ft/#'s
JaayTeee is offline
