Sea Strainer/ flushing
Old 05-31-2010 | 11:01 AM
Default Sea Strainer/ flushing
Anyone ever use basic "garden hose" quick connects on their strainer washout ports? Seems like a simple way to go about it... just click the hose on and flush them. My only reservation is that the suction would open the quick connect and let air in while underway.
Austin is offline
Old 05-31-2010 | 11:12 AM
you are correct,that is why you must use the marine style with the plugs installed during normal operation,no air leaks.
mike tkach is offline
Old 05-31-2010 | 11:23 AM
Thanks for the reply Mike.
Austin is offline
Old 05-31-2010 | 12:50 PM
you could install a ball valve before the quick release also
SHAWN DAVIS is offline
Old 05-31-2010 | 01:23 PM
Airpacker's Avatar
I used a stainless ball valve between the strainer and the hose connector. Open valve when flushing, close while boating. Works slick.
Airpacker is offline
