Bravo Drive trims up, not down. >
Old 06-01-2010 | 09:51 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Bravo Drive trims up, not down.
No click, no nothing. I have not had a chance to investigate yet.
Worked on Saturday evening. Trailered it home for 3 hours on Sunday and it wouldn't trim down when I backed in the driveway.
The boat does not have any electronic trim limiters or anything.
Any thoughts before I tear into it?
Thanks in advance.
Sydwayz is offline
Old 06-01-2010 | 02:26 PM
Panther's Avatar
Frank's Marine Service
jump the solenoid on the pump and see if it works, back-track from there.
Panther is offline
Old 06-01-2010 | 03:18 PM
tomtbone1993's Avatar
+1
tomtbone1993 is offline
Old 06-01-2010 | 04:03 PM
Thunderstruck's Avatar
Brian, check the connectors under the dash for the trim switches. Mine rattle loose on rough trailer rides.
Long time cult member.
Thunderstruck is offline
Old 06-01-2010 | 05:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Thanks guys. I know it's all logic--literally. I just wanted to see if there were any time saving troubleshooting tips and this helps.
Sydwayz is offline
Old 06-02-2010 | 01:08 AM
Ditto!!!!!!!!!
I have had wires pop off the back of the trim switces a couple times at LOTO after running in rough water.
Griff is offline
Old 06-02-2010 | 05:14 PM
Check the connection at the pump. I had the same problem Saturday. Pushed the round plug all the way in and we were back in business.
powerquest rick is offline
Old 06-15-2010 | 02:33 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Bad solenoid. Thanks everyone.
Sydwayz is offline
