Port Tach jumping around >
Old 06-01-2010 | 09:22 PM
Default Port Tach jumping around
I just finished installing new 500efi motors in my boat and took it out for the first time today and my port tach is jumping around is there a place that a wire is plugged in for this that could be loose causing this? Finding all the little bugs from the change over.
Irishtornado is offline
Old 06-02-2010 | 11:55 AM
i had to replace my tach becasue it got some water in it and was doing the jumpping thing. at WOT i was bouncing around 7k haha
mittens is offline
Old 06-02-2010 | 12:19 PM
Default Fixx
swap tacks,if its still their check alternator volts..suspect alternator feedback to tach and might be on its way out..
FIXX is offline
Old 06-02-2010 | 01:19 PM
I was just thinking as they worked when I pulled the 496's that it might be a wire issue on the 500efi's didn't know if there was a tach wire on the distributor that could be causing it.
Could very well be the tach although they are only 2yrs old so I'll try switching them and see if it does it on the opposite side or not.
Old 06-02-2010 | 02:52 PM
BY U BOY's Avatar
Check the ground.
BY U BOY is offline
Old 06-02-2010 | 03:19 PM
Originally Posted by BY U BOY
Check the ground.
Ground on gauge?
Old 06-02-2010 | 03:27 PM
Default Fixx
didn't see efi i replaced a alternator last week on a 365 mag,,tach was jumping sporadic idle (high & low)..when a alternator goes bad it will throw ac voltage,that's what was causing my issue's on a customers boat..
FIXX is offline
Old 09-02-2010 | 03:03 PM
still doing this now on both motors
Old 09-05-2010 | 06:38 PM
Steel Outlawed's Avatar
Check out my thread. Search for tach 500 efi. I would give you the link but I'm on my phone. Post #12 is what did the trick. Sounds crazy but it works. Call me of you have any questions. 864-420-4932
Steel Outlawed is offline
Old 09-06-2010 | 03:45 PM
Here you go. Back home with a computer.
http://www.offshoreonly.com/forums/g...s-500-efi.html
