Silverado SS tow capacity
Old 06-03-2010 | 12:33 AM
Default Silverado SS tow capacity
Hey Everyone, I have been looking into buying a boat and I'm not quite sure as to what size of boat my truck would be able to handle safley. I have a 2006 Silverado SS (2WD) and I'm not exactly sure what the tow rating is.. I keep getting conflicting info on the web and I'm in Afghanistan right now so it's not like I can just go outside and check for myself. I have been looking around for a Pantera 24 or similar.. Any Advice for a new boater?
BCrosscheck10 is offline
Old 06-03-2010 | 05:50 AM
I pull a Baja 242 Islander 90 miles each way every weekend with mine. It only gets about 9 mpg pulling it though. My Silverado SS is a 2003 and has the AWD system with 4:10 gears. I think the 2006 Silverado SS trucks have 3:73 gears though. That might make a difference in pulling power.
brunnesa is offline
Old 06-07-2010 | 09:05 AM
My father-in-law has one, an AWD version and I have pulled my 242 with it and it was fine. He also pulls his 24 ft deck boat with out issue.
jmrapp is offline
Old 06-08-2010 | 08:31 AM
This is strait from GM
Vehicle*
Axle Ratio
Maximum Trailer Weight
GCWR
Silverado SS
6000 V8
3.73
7,800 lbs (3 538 kg)
13,000 lbs (5 897 kg)
Tow-N-One is offline
Old 06-08-2010 | 08:48 AM
Fenderjack's Avatar
Pirate of the Chesapeake
You should be fine to to up to atleast a 30 ft boat with it. The newer ones went to a 373 gear and 2wd. Pre 05's were awd and used a 410 gear.. still the same tow rating..
John jr
Fenderjack is offline
Old 06-08-2010 | 10:42 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It's a half ton truck! NO FOOKING WAY. I know this is not your info; that number has to be a mistake.
Sydwayz is offline
Old 06-08-2010 | 12:12 PM
John jr
How much does an average 30' boat weigh? My 242 islander weighs around 6200 lbs with fuel and everything. I was wanting a bigger boat, but did not think my truck could tow it.
brunnesa is offline
Old 06-08-2010 | 12:17 PM
Quinlan's Avatar
Gotta be the GVW
Quinlan is offline
Old 06-08-2010 | 03:05 PM
ziemer's Avatar
I've got an '07 Avalanche, similar in nature but with a 5.3, 2wd, & 3.73 rear. I tow a 24' SE Pantera with mine and it's no problem. My boat, trailer, & gear, ready to go weighs around 5800 lbs.
ziemer is offline
Old 06-08-2010 | 09:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Pretty much a golden rule:
Anything bigger than a single BB = 3/4 ton truck.
Sydwayz is offline
